Ventana Systems UK Forum Last active: Never
Not logged in [Login - Register]
Go To Bottom
Printable Version | Subscribe | Add to Favourites   Post new thread Poll:
Author: Subject: No GET XLS CONSTANTS in version 5.10.a
ppmvanhooff
Member Is Offline
[*] posted on 9-10-2010 at 08:39 Reply With Quote
When i upgrade from 5.10.x to 5.10.a, Vensim won't read in values from an xls-file (using GET XLS LOOKUPS). The message is that there might not be a 'live connection'. When I return to a previous version all works well again.
Is this a bug, or am I missing something that has been added or changed?
View User's Profile View All Posts By User U2U Member
Member Is Offline
Mood: No Mood.
[*] posted on 9-10-2010 at 09:35 Reply With Quote
There is a known problem if you are using a named range that begins with 2 letters followed by a nonletter. What is the call that is causing the problem for you?
ppmvanhooff
Member Is Offline
[*] posted on 9-10-2010 at 12:56 Reply With Quote
GET XLS CONSTANTS('srdata.xls', 'dieselstad', 'pr_ltr_d')
So the problem is the underscore after <pr>.
Will this issue be solved in the near future?
Go To Top
Powered by XMB
Developed By Aventure Media & The XMB Group © 2002-2006
[queries: 15]
[PHP: 81.4% - SQL: 18.6%]
