Reset in Synthesim
Moderator: Administrator
drees
Reset in Synthesim
Post by drees »
Hi Tony
Does Sable have the equivalent of the two reset buttons that Vensim has in synthesim mode? One is the 'rest current slider to base model val (Home)' and the other is the 'reset all constants/lookups to base model vals (Ctrl+Home)'
David
Not at the moment (but I will request it as it needs to be done in the Vensim engine).
drees
Post by drees »
Thanks Tony. If you have any ideas of a workaround so that I can make it easy for clients to remember and reset sliders to their base values that would be great.
Thanks again for your rapid response.
David
drees
Re: Reset in Synthesim
Post by drees »
Hi Tony
Did you get a response to this one? I am interested, as not having that facility does make it more difficult for clients to use the models. When they've changed a value they have no way of knowing, in the interface, what the original or baseline value was. I'm trying to make my models as easy as possible for clients to use and this would facilitate that enormously. Currently, I simply put in a text statement by the slider showing the baseline value, which is a bit clunky although it does work
Cheers
David
Try
SYNTHESIM>RESET
I may need to update the underlying Vensim engine, but it should work.
drees
Post by drees »
Hi Tony - works great! Thanks once again.
David
