After publishing a update of a model in Vensim I try to import it in my current Sable Project.
Now I get the error message: "The file name abc.vdf is protected (part of a package). Choose another."
How to overcome the error to get it in my Sable project?
Thx and best regards
F
Problems with Publishing updated model and using it in Sable project
Moderator: Administrator
Re: Problems with Publishing updated model and using it in Sable project
It sounds like you included a runname when you published the model, and then tried to create a run titled ABC.VDF.
Sorry for asking again. Since I am pretty new in using Sable I actually dont know how to avoid that error.
Indeed, I added the run abc.vdf inlucding a abc.cin file to the model since I have several graphs showing figures for several runs.
Where do I create additional runs?
When publishing, make sure that the model is the only thing included in the VPM file and it should work without issue.
