Help in Extreme condition testing
Jindu
Post by Jindu » Fri Apr 12, 2019 4:47 pm
Hello Everyone,
I’m trying to carry out Extreme Condition Test but it gives an error message “Floating point error computing - Order Fulfillment Ratio - at time = 0.000000”. Trying to save the results anyway.
I would really appreciate some help in sorting out this issue.
Experiment1A.mdl
(6.95 KiB) Downloaded 13 times
Re: Help in Extreme condition testing
Post by Administrator » Fri Apr 12, 2019 10:40 pm
It's a simple division by zero. "Desired shipment Rate" is zero which causes the problem.
The quickest way to correct this is to use the ZIDZ function.
Jindu
Post by Jindu » Tue Apr 16, 2019 11:11 am
Thanks for your reply it helped a long way.
