Maths - Integrals
JoseG
Maths - Integrals
Post by JoseG »
Hi all,
I am trying to represent this mathematical expression into a SD-Vensim model:
X(t)=∫X(t,r)f(r)dr
The integral is defined between zero and R=2 (for example)
X(t,r) represent a variable (disease incidence) at time t with a rate r, and is defined by the logistic equation X(t)=1/(1+(1-Yo/Yo)*EXP(-r*t)).
Yo is a parameter constant.
f(r) is a density function, specifically, the exponential distribution: f(r)=EXP(-r/d)/d.
d is a parameter constant
Is it possible to translate this into a stock-and-flows diagram model in Vensim?
Thanks in advance
Re: Maths - Integrals
Have you tried implementing this yourself? If yes, feel free to upload the model and explain why you think it's not correct.
1. What is "disease incidence" measured in?
2. What is the rate "r" measured in?
You would usually calculate the rate at which disease occurs, then put this into a level which would be the number of people/animals/whatever that have the disease at a point in time.
JoseG
Post by JoseG »
Disease incidence represents the proportion of plants diseased out of the total of a plot, and therefore is dimensionless.
the rate of disease, r, is 1/time (e.g., 1/day)
I create a model with a stock (level) for disease incidence, but I have problems in including the exponential distribution of r on it
