Level or Simultaneous Function?
aalto-comnet
Post by aalto-comnet »
Hello!
I am receiving a simultaneous equation error due to the fact that part of my model is about modelling behavior and the loops do not involve any stocks. This can be solved either by turning one of the variables to Level or with the Simultaneous function. The thing is, which one should I choose?
Is a Level variable supposed to be only for stocks? In the link below, it is stated that Levels are also called accumulations, stocks, and states. Could it be a behavioral state as well then?
https://www.vensim.com/documentation/in ... ?21995.htm
If turning a variable into Level is not the correct approach for my model, which of the variables of my model should be turned to Auxiliary Simultaneous, with what initial value, and why?
Attached my (draft) model.
Thank you!
eating.mdl
(1.84 KiB) Downloaded 528 times
Re: Level or Simultaneous Function?
Definitely a level here. Hunger will increase with time, and decrease as a result of eating.
aalto-comnet
Hi! Thanks for replying! So, as far as I understand, levels can be used even if we are not accumulating tangible items, right? In order to model, for example, various behavioral aspects.
Yes. Hunger can be treated like a level, just like say morale could be for an army.
aalto-comnet
Thanks for clarifying! :)
