Hearne' method
bahri
Vensim version: PLE+
Hearne' method
Post by bahri » Mon Apr 15, 2019 10:36 am
Can someone please tell how to do "sensitivity analysis"
for a lookup function using a Hearne's method ?
Re: Hearne' method
Post by tomfid » Mon Apr 15, 2019 1:49 pm
I assume you mean this?
https://onlinelibrary.wiley.com/doi/abs ... 09.00058.x
The paper is paywalled, but I'm going to speculate that in general it would be tricky to implement. You'd have to have a library of functions with desired properties that meet all the reality checks needed for them to make sense in context.
A simple method for doing sensitivity analysis on a lookup is easy, if the lookup is properly normalized to begin with, like:
price = reference price * effect of inventory lookup( inventory / reference inventory )
With this construction, you can already shift and scale the effect using the reference parameters. Then you could add additional distortions of the effect, like:
price = reference price * effect of inventory lookup( inventory / reference inventory ) ^ sensitivity scale
(Bear in mind that this has infinite slope at 0 if scale < 1.)
Or, you could mix two different shapes:
price = reference price * (weight to A*effect of inventory lookup A( inventory / reference inventory )
+ (1-weight to A)*effect of inventory lookup B( inventory / reference inventory ))
bahri
Re: Hearne' method
Post by bahri » Tue Apr 16, 2019 6:23 am
Hi Tom,
Yes the link goes to the Hearne's method.
and thanks for other useful description.
