I'm using the MESSAGE function to give some warns when a variable gets a specific value.
the question is: where I can display the scrolling list of warnings, because it doesn't appear.
MESSAGE
MESSAGE
I check in Tools>Options, and the option is check in Display. But it doesn´t work.
This is the way I'm calling it:
if then else (P1<0, MESSAGE('Need 1',1) , MESSAGE('Need 0',1))
if I use another option in the display parameter, everything works fine, except in the option 1.
Thank's
[Edited on 2-10-2005 by rolando]
Thank's
How can I....
Thank's for the last post, it help's.
Now the MESSAGE is working fine with the display option 1. But now, I just want to know if I can display the value of a variable in the list of warnings. For example:
WARNING: the process 5 is not working
but in other run, the process 5 is working fine, but the process 6 not, so I need to display.
WARNING: the process 6 is not working.
thank's.
thank's.
