I need to use the queue FIFO structure, but I don't understand how to use the lookup variable.
I did an simple example to understand how to use a lookup in a queue, and I used the same lookup:flat that comes in one of the examples of the reference manual. Everything work's as I think, but when I change the lookup variable to other values, the same result was display. I change the values, like this:
input : 0
output: 3
input: 3
output: 1.
My questions are: The lookup variable is a function where I can match an input with one output? And How affect the queue structure?
Lookup
