I'm running a model using Vensim Runtime and it isn't working with Excel link.
I created a simple test with and without the function GET XLS CONSTANTS('file.xls', 'sheet' , 'cell' )) and doesn't work.
Of course the model is working when I used Vensim DSS.
The same error occur using Vensim Reader.
Any hint?
Patricio
Yes, of course. Actually when I ran using DSS version works.
Using the Vensim Runtime I get the message:
"Model has errors - cannot be simulated".
I also verified the row and columns definition because it changes using Spanish version of MSOffice .
The error message you get suggest the .vmf file is not quite right. In Vensim DSS do a model check model to make sure it is fine, then save the .vmf file again. Then try it with Runtime/Model Reader.
