how to make vensim update get xls constants?
After changing values in an xls-file that I use as input and saving that xls file, vensim does not automatically read the new values. My work around is to close the model, reopen it and then vensim reads in the new values. My question is wether there is a key-combination (ideal), or at least a menue-command that I can click to make Vensim pick up the new values so I don't have to close the model every time. Please not that I am working on the mac version of Vensim so that it picks the values directly from the file not from the excel application.
Re: how to make vensim update get xls constants?
This is a Mac limitation. GET XLS uses GET DIRECT on the Mac, so the file has to be saved for changes to propagate. On Win GET XLS passes live values.
saving the xls file does not help.
saving the vensim file does not help either.
Only closing and reopening the vensim file helps.
But that is subotimal (I have to move the window to second screen, resize it, show hidden elements etc.) before I can start working again.
It seems Vensim does not re-read the xls file each time it runs a simulation. How can I make Vensim re-read the xls-file?
That does sound wrong. I'll test.
Can you post an example with step by step instructions so we can test?
I am now running into a similar problem, using CSV files with GET DIRECT CONSTANTS. I ran the model with no problem when I had a single, unified CSV file. I would change the CSV file and Vensim would use the modified version. However, I have just split the data set into four different files, and Vensim no longer reads in data even after I save the files. I have to go to Settings -> XLS files -> Modify Selected (with no changes) -> Add Editing to force it to look again. (Or restart.)
Another change in my case is that I just updated to the new "Anniversary" edition of Windows 10. (Actually, not my choice -- MS did it for me, with no option to postpone.)
I attach my model, with data files.
Thanks,
Eric
Thanks,
Eric
- p2cs-multisector.zip
- (10.41 KiB) Downloaded 205 times
This just crashes when I attempt to run it. Will investigate.
Thanks very much. And interesting... it doesn't crash for me.
Can you give me a list of parameters that are not updating? My tests here are working fine.ekempbenedict wrote:I am now running into a similar problem, using CSV files with GET DIRECT CONSTANTS. I ran the model with no problem when I had a single, unified CSV file. I would change the CSV file and Vensim would use the modified version. However, I have just split the data set into four different files, and Vensim no longer reads in data even after I save the files. I have to go to Settings -> XLS files -> Modify Selected (with no changes) -> Add Editing to force it to look again. (Or restart.)
Thanks,
Eric
Yes, I was changing "investment utilization sensitivity" in the CSV file and it was not updating in Vensim.
ok, I think I've found the bug. Just need to do some testing before creating a new build.
Thanks very much!
FYI, I discovered that part of the problem was the timestamp on the file. I have several versions of the CSV input files, and before a run I copy one version into the master using a Windows batch file. I realized that I have to "touch" the file to bring it up to date so Vensim knows that it's changed. This is my revised batch file:
use.bat
That works. If anyone is interested, it works like this:
Then it copies 'scalar_constants_my_scenario.csv' into 'scalar_constants.csv' for the run.
Eric
use.bat
DEL scalar_constants.csv
COPY scalar_constants_%1.csv scalar_constants.csv
TOUCH scalar_constants.csv
command line> use my_scenario
Eric
