FIFO Function
Ifeanyi
FIFO Function
Post by Ifeanyi »
Hi Tom,
Please can you advise me on how to use the FIFO function in vensim ple? Can it be used in an inventory management model? The manual does not seem detailed enough. Thanks
Re: FIFO Function
Have you looked at the sample model that is in the help system?
http://www.vensim.com/documentation/ind ... _queue.htm
It might be better if you look at the sample first and see if it can be adapted to what you want to do. And then if you have trouble, post back with a little more information about what you want to do.
Re: FIFO Function
The QUEUE functions aren't available in PLE (or if they are, it's a bug).
