Hello Folks,
I'm trying to make Monte Carlo Sensitivity analysis on venapp for the users in order for them to change the input value in the preset ranges.
I tried the following methods that I've read from the modules but It unfortunately didn't not work for me.
For example,
Discount rate(%) = 10
Gold price($/oz) = 1000
MODVAR, "Discount rate(%) MIN",
MODVAR, "Discount rate(%) MAX",
MODVAR, "Gold price($/oz) MIN",
MODVAR, "Gold price($/oz) MAX",
SLIDEVAR,""Vol MIN"",23,83,15,5,,,,
SLIDEVAR,""Vol MAX"",47,83,15,5,,,,
...... etc
When I run the venapp, the value didn't show up on the screen. I can't figure it out what the errors were. Could anyone help suggesting to fix this problem?
I appreciate any help.
Thank you so much.
Inthan
Set MIN/MAX Values for Monte Carlo Sensitivity in Venapp
Re: Set MIN/MAX Values for Monte Carlo Sensitivity in Venapp
Can you post the venapp and model? It's impossible to see what the error is without them.
Can we assume that you have variables named "Discount rate(%) MIN" etc.?
Hi Admin, Hi Tom,
Thanks for your response.
Yes, I've all of these variables in the model and it's constant variable.
Sorry, I'm revising the model and I'll post it asap for your to check it out.
Inthan
Inthan
Hi Tom,
I was confusing about the variable.
I've a variable named " Dicount rate (WACC, %)" then I put "MIN" or "MAX" at the quote to specified the min and max value for sensitivity analysis. For instance, " Dicount rate (WACC, %) MIN", for the minimum value, and Dicount rate (WACC, %) MAX", for the maximum value like if I use RANDOM UNIFORM (MIN, MAX) in Monte Carlo Sensitivity in Vensim.
Here I've uploaded the models.
Could you please check it out for the errors.
Thank you so much.
Thank you so much.
Appending MIN or MAX to the name isn't going to do anything, because there's no such syntax support in Vensim. You could, however, create explicit x_MIN and x_MAX variables and use those in your interface and random definitions, however.
Hi Tom,
Thank you very much for your suggestion.
I'll do so.
Best regards,
Inthan
I'll do so.
Best regards,
Inthan
