Dear all,
I'm trying to use an old model of ours and upon loading the external file I get the "External function mismatch 51050 (got 400) error" (http://www.ventanasystems.co.uk/forum/v ... php?t=5512; http://www.ventanasystems.co.uk/forum/v ... 050#p15002). My understanding is that I need to recompile the dll using the new header file that I find in the ..\Vensim\COMP folder of the new VenSim installation. This creates multiple errors when I try to compile the new dll. Should I also use updated venext.def and venext.c ? Using those eliminates a few errors (Using the old venext.c creates multiple errors in that file). The errors that I still get are because of "GMEM_ZEROINIT", "GMEM_MOVEABLE" and "JBUF". Any advice? Why does the exchange of the header file create multiple errors? Compiling with the old header file works just fine.
I am using VENSIM DSS 6.4E and Visual Studio 2013 on a Windows 7 (64bit) computer.
Thank you in advance!
New Header file compiling problems
Re: New Header file compiling problems
Are any of those errors Vensim ones? I don't recognise JBUF. "GMEM_ZEROINIT" and "GMEM_MOVEABLE" are to do with memory allocation, so you are probably missing a header file.
Thanks for your reply. I figured it out i had to merge my old vensim.c and some functions from the new one. Its quiet stressing to compile a new dll with the new header file because a lot of functions have changed in some ways. Thank you anyway.
