Anyone can hekps me to solve this equation to convert into VENSIM PLE?
I have to parameter which W and C
How to solve this type of equation
- Convert to the vensim eq PLE
- eqVensim.JPG (12.42 KiB) Viewed 3629 times
Re: How to solve this type of equation
This isn't a dynamic problem, and therefore Vensim is not the tool of choice.
However, you could solve this in Vensim Pro/DSS, using arrays.
In PLE, you could probably simulate this by treating b as time and using a stock to do the summation.
Either way, some other tool would probably make more sense.
Then how to structure the equation to make sure its loop so that it can be summation?
- try1.mdl
- File Problem
- (2.12 KiB) Downloaded 155 times
1. There is no loop, because this equation has no feedback.
2. "Final" needs to be a stock. Then:
Final = INTEG( Rate, 0 )
Rate = W(b)*C(a-b+1)
a = ...
b = time
INITIAL TIME = 1
FINAL TIME = a+1
Note that FINAL TIME is > a - the stock introduces a discrete lag of one TIME STEP, so if you want Final to contain the complete sum, you have to run one step past the end.
Why not do this in a spreadsheet? Seems like it would be easier.
a = ...
b = time
INITIAL TIME = 1
FINAL TIME = a+1
Thank you for helping me
But I'm still have a lot of problem
The reason I don't use excel because main topic is to use VENSIM as dynamic software
Here attached model update by me and hand calculation as required result
I think still need loop since in each row not used previous data or information
Can you help me on this Mr. tomfid?
- IMG_4359.JPG (1.53 MiB) Viewed 3611 times
- try1.mdl
- (2.22 KiB) Downloaded 146 times
Ahh ... if the summation is also time varying, there's no practical way to do this in PLE.
Can you help me complete that equation using my file because I want try to run in DSS or Professional trial version first as consider to buy that software?
I really wouldn't recommend Vensim for this task, unless it's a small part of a larger dynamic model. There will be a significant inefficiency, because arrays are static. You would have to create an array with the full dimension of "a" which would then be empty 50% of the time, and there would be a lot of overhead for something that's otherwise quite simple. You could do this in Python for free with just a few lines of code, for example.
I don't have time right now, but could work out an example later today.
Did you able to solve it using Python?
I haven't had a chance to work up a Vensim example.
It would be easy to solve in Python, but I think this isn't really the place to discuss it.
