Dear Sir/Madam,
Hope you're doing great.
I am doing my research on risk management in Indian food supply chain. For the solution methodology part, I have selected the SD modeling. For this, I have gone through several papers and one paper I got relevant to my work, for the reference I am attaching that paper. In this paper, can someone explain the following points
(1) In Figure 5, how the Chemical supply chain transportation (CSCT) system and Risk factor Stock and flow diagram is connected?
(2) How they calculate the risk scenario simulation which is given in Table 2?
It would be grateful for me if someone can explain the procedure how they connect the risk stock and flow diagram to CSCT stock and flow diagram.
Thanks and regards
Rishabh Rathore
Note: Please refer the paper
Request for clear some doubt
- Vensim version: PLE
Last edited by rishabh.mech10 on Tue Apr 11, 2017 1:59 pm, edited 1 time in total.
Re: Request for clear some doubt
Is that paper copyrighted? It looks like it is, please check and if it is, please delete it from the forum.
Questions regarding a specific paper should probably be sent to the authors. Without the model, it's impossible for us to advise you.
thank you for reply.
I also removed the paper from the forum
thank you
thank you
