the Java example of Vensim DLL
when I run the java example of Vensim DLL ,once I click the simulate button,there is an dialog box shows "Can't write to the file base.vdf(busy or insufficient permission)'',it's grateful for heiping me with this problem.
Re: the Java example of Vensim DLL
Do you have the run open in Vensim as well?
And what path are you running the sample from? Make sure it's in your Documents folder or some other place that you have permissions to write to.
Thank you!when I put the example in Document folder,the model run well.Thank you very much.Administrator wrote:Do you have the run open in Vensim as well?
