Dear sir,
I am trying to run the simulation for my models.
But following errors has come
What does it mean?
ERROR: Fix floating point errors before entering SyntheSim mode.
ERROR: Floating point error computing - Vehicles used - at time = 0.312500.
Trying to save the results anyway
the values are wrong or the structure of the model?
Error in the model
- Vensim version: PLE
Re: Error in the model
Most floating point errors are a division by zero.
If you upload the model, I'm sure we can identify what is wrong.
dear sir,
Please find the attached model.
kindly suggest the necessary modifications.
Thank you
Thank you
Last edited by rishabh.mech10 on Wed Jun 07, 2017 3:45 pm, edited 1 time in total.
Look at the value for "vehicles used". It's 731588, you only have 100 vehicles so you need to limit the outflow.
I think the vehicles section needs some work anyway. The "number of available vehicles" should influence the "Backlogger order transported", but you've got the "backlogged order" influencing the "number of vehicles". I'd start with a constant number of vehicles and use that to calculate the transport rate. Then you can look at increases/decreases in the number of vehicles when you have the transport rate working.
Dear sir,
Thank you for your valuable suggestion.
I'll incorporate your suggestion and get back to you
Thank you
Thank you
