i am trying to learn the logic behind age.mdl file available in the Sample/Extra in Vensim help.
can anyone show me how the aging variable is split?
Splitting a rate variable
Re: Splitting a rate variable
It's a little tricky to find, but it is all in the documentation at
http://www.vensim.com/documentation/ind ... apping.htm
Look at example 2 on that page.
The model also contains subscripts, if you are not familiar with those, you'll need to do that first.
http://www.vensim.com/documentation/ind ... cripts.htm
