"As Date" question
billh
"As Date" question
Post by billh »
I've got a model that has units for time set to hour and has the pertinent information in the Date Display boxes of the Time Bounds tab of the Model Settings window: Date, YYYY-MM-DD, 2016, 10, 1, Hour.
On the Control Panel Time Axis tab, I've checked the "As Date" checkbox.
My graphs have 0000-00-00 as the date label for each marked point on the abscissa.
If I uncheck "As Date", I get the appropriate value of hours along the abscissa.
If I set the Base date units to Day, I get dates in the proper format, but they appear to be calling each hour a new day--the end of the simulation is now shown in 2031 instead of 2017.
Am I doing something wrong? Do I need to figure out how to create a new time base?
Re: "As Date" question
I think the documentation needs improvement on this. Go to Model->Settings, here you can set the date display settings, you should be able to change these to fix the display.
billh
Post by billh »
That sounds reasonable, but I'm not sure what else to try.
On the left side, I've got an initial time of 0, a final time of 5831 (yes, it's the same long model I wrote about recently), and time step is 0.125. SAVEPER is 1, units for time is hour, and I've currently selected Euler integration.
I think that's all essential for the model as I want it to work.
On the top right, I've got (in order) Date and YYYY-MM-DD. That sounds like what I want.
That leaves the base date. I want this to start at the beginning of a "water year," which is October 1, so I did that.
The remaining choice is base date units.
If I select Day, I get dates from 2016-10-01 through 2030-11-02, suggesting it's taking the numeric hour as a numeric day.
If I select Hour, I get dates from 0000-00-00 through 0000-00-00.
That's all with "As Date" selected on the Time Axis of the Control Panel. If I uncheck that, I get the expected number of hours on graphs.
What am I missing?
Can you email the model to us so we can take a look? It could be a bug, might also be some incompatible settings.
