Exploratory Modeling and Analysis software
Ifeanyi
Post by Ifeanyi »
Hi Tom,
Please how does the EMA software work with vensim? How is the EMA approach to modeling different from doing several simulation runs within a model to generate insights? What are the benefits/uses of the EMA? Is it compatible with all versions of vensim including PLE? Thanks
Re: Exploratory Modeling and Analysis software
http://simulation.tbm.tudelft.nl/ema-wo ... tents.html
The EMA workbench runs with the .dll, which is part of Vensim DSS.
The big difference is that it provides a lot of extra capabilities for generating inputs and analyzing large output datasets, even comparing multiple models. So, you can explore a model's parameter set more than is practical by hand.
As always, it's garbage in, garbage out, so a high-quality, robust model is a prerequisite.
