Get Subscript Constants from different sheets
lfbpmb
Post by lfbpmb »
Does anyone know if it is possible to pass the subscript name as a string parameter so I can get a value for each subscript item from different sheets in Excel?
I´m looking for something like:
GET XLS CONSTANTS('DadosORCPRs.xlsx', [PRs], 'B2' )
The idea is that each value comes from a sheet with the same name of the subscript item.
Re: Get Subscript Constants from different sheets
Using a string variable should work. Something like:
Sheet : (sheet1-sheet3)
Sheet name[sheet1] :IS: 'fred'
Sheet name[sheet2] :IS: 'bob'
Sheet name[sheet3] :IS: 'mary'
myval[sheet] = GET XLS CONSTANTS( 'filename', sheet name[sheet], 'a1' )
lfbpmb
Post by lfbpmb »
Thanks for your answer.
I´m trying using a string variable that gets the subscripted values also from excel but I´m getting an error.
The model is attached. The string variable with the error showing is "PRsstr"
OrcSubscript.mdl
(2.85 KiB) Downloaded 168 times
Ah ... you can't use GET XLS to retrieve strings. They have to be in the model. You can put a default value in the equation and supply overrides in a .cin file however.
Also, you forgot the subscript on the uses of PRsstr.
"%Orc 2341 PR"[PRs]=
GET XLS CONSTANTS('DadosORCPRs.xlsx', PRsstr[PRs], 'B2' )
lfbpmb
Post by lfbpmb »
Thanks I lot, Ill try it.
Please enter your serial number in your profile. Entering incorrect information usually ends up in a ban.
