Taking a value of a specific time
Hossein
Post by Hossein »
Dear Tom, Administrator,
I want to make a comparision between two consecutive value by IF THEN ELSE function. Then, I need to take these values and compare. Somthing like the following example.
IF THEN ELSE (value at Time i = value at Time i+1, 0, value at Time i+1 - value at Time i)
Could you please help me?
BR,
Hossein
Re: Taking a value of a specific time
Post by Hossein »
I just solved it by constituting Time i+1 via DELAY FIXED function by one unit. Afterward, I deducted the two variables and it works! However, is there another direct solution?
Hossein wrote:I just solved it by constituting Time i+1 via DELAY FIXED function by one unit. Afterward, I deducted the two variables and it works! However, is there another direct solution?
This is the correct way to do it.
Hossein
Post by Hossein »
I want to get the value of the first time of a flow and use it as the initial value of its level (please see the attached figure) i. e. I want to use the value of "Emission rate" at the first time as the initial value of "Total emission". Could you please help?
BR,
This should work, have you tried it?
total emissions = integ ( emissions rate, emissions rate).
Hossein
Post by Hossein »
Dear Administrator,
Thanks for your reply.
Actually, I did not try it because I thought since emission rate is changing, the initial value of total emission would also change! However, now, I tried it and worked!
Thanks again.
Setting
Total Emissions = Emissions Rate
is dimensionally inconsistent (TonC vs. TonC/year, for example).
You probably want to include some kind of time constant on the right hand side, so for example
Total Emissions = Emissions Rate*Initial History Duration
Initial History Duration = 1 year (or whatever).
