I am using DSS FOR Windows Version 6.3 (x32) and I try to do a Sensitivity Analysis.
I go to Model>Simulate>Sensitivity and I set the parameters. I click on Sensitivity.
However, after running, when I want to see a Sensitivity Graph, it says "First run must be sensitivity run to get results. Try strip graph." What should I do?
Thank you
Sensitivity analysis error - Vensim DSS
Re: Sensitivity analysis error - Vensim DSS
Make sure the sensitivity run is loaded first, see
http://www.vensim.com/documentation/ind ... tasets.htm
