Suggestion: Data vars with explicit :NA: should not trip Warnings
Travis
Post by Travis »
We input some data series via a VDF file. The data doesn't cover the full simulation time period, so we get Vensim warnings about data not existing for these variables.
I would like to make the warnings go away -- would make real warnings be more evident. We tried adding :NA: for the years we don't have data but the warnings still persist.
I feel if we've explicitly added :NA: for values, that should be treated as intentional and not cause the same warning.
I think suppressing all warnings is bad modeling practice, but having a model that always has warnings is also not very useful modeling practice.
TIA
Re: Suggestion: Data vars with explicit :NA: should not trip Warnings
Can you upload an example?
I've never tried it, but you can use a .cin file to suppress the warnings:
https://www.vensim.com/documentation/in ... _files.htm
