Hi everyone,
Is there any way to use the values of a variable (type Auxiliary, sub-type Normal) as input data for a Lookup variable or an Auxiliary-with-Lookup variable? For example, if variable A is a curve, how could it be "converted" to a lookup to be used by other variables within the same model?
I know this could be realised through, for example, exporting the values of variable A to an Excel spreadsheet, then copy&paste the data into the equation box of a Lookup variable (or that of an Auxiliary-with-Lookup variable). But is there any other way of directly doing it within one Vensim model, without having to use Excel?
Many thanks.
WZ
Convert a variable's value as input data for a Lookup
- Vensim version: PRO
Re: Convert a variable's value as input data for a Lookup
Is this what you're after?
http://vensim.com/documentation/fn_vector_lookup.htm
