"EDIT", "VIEW", "INSERT" not active
osenk123
Post by osenk123 »
Hello
I'm a new user of Vensim PLE version. After program installation I was not able to use menu EDIT, VIEW and INSERT - there were just not active. When I uploaded any example model and tried to run simulation I got message - Stop from Vensim, Can only use this in sketch view.
Could somebody tell me what I'm doing wrong or I have a problem with proper installation of the program.
Thank you in advance
Janusz
Re: "EDIT", "VIEW", "INSERT" not active
Did you install using admin permissions?
osenk123
Post by osenk123 »
I have admin rights on this computer although it is a company laptop.
I don't know how else I can check possible rights that I should have.
I tried as well to start the program "as administrator" but without success.
Can you email me please, vensim@vensim.com?
For everyone else: the issue here is corporate user management software that locks up the normal path to vensim.ini, which prevents Vensim from running. There's a workaround, and a future release will avoid the problem.
