Hi, I have just upgraded my Vensim Pro 6.4 to Vensim Pro 7.1. However, when clicking sample models provided in Vensim Help, nothing happens. Previously when using Vensim Pro 6.4, clicking a sample model (usually in the form of a hyperlink given at the bottom of the explanation of a function) will immediately open that sample model. How to solve this problem?
Thank you so much.
WZ
Can not open sample models after upgrading
- Vensim version: PRO
Re: Can not open sample models after upgrading
Did you install using admin permissions?
It sounds like the file associations have been messed up.
Yes, I did. I can open those sample functions by finding them here C:\Users\Public\Vensim\Models\FunctionExamples. However this is troublesome. Is there any solution? Thanks.
Administrator wrote:Did you install using admin permissions?
I'm not sure if it's an OS permissions change or what, but I think this is becoming widespread. We'll look into it.
