question
elhamdavoodi
question
Post by elhamdavoodi »
hi all,
i am master student in water resource management
i have a question in vensim model
how can put this equation in this model?
if A>0 , X(i)=0
else A<0, X(i)=X(i-1)+B
thanks. :)
Re: question
I'd be wary of such an equation, but you could implement it as:
x previous = DELAY FIXED(x,interval,x)
y = IF THEN ELSE( A>0, 0, x previous+B )
Re: question
elhamdavoodi wrote:hi all,
if A>0 , X(i)=0
thanks. :)
It might be better if you explain what you are trying to do, maybe we can figure out the correct equation.
elhamdavoodi
Re: question
I am using Vensim PLE V. 6.4 in my thesis. I had to use below equation in vensim model.
APWL: is accumulated potential water loss.
When surface infiltration>0, APWL =0,
When surface infiltration<0, APWL(i)=APWL(i-1)+Surface Infiltration(i)
i-1 is refer to APWL in one month ago.
I attached the sample of this equation.
please help me.
thanks.
Elham
Re: question
Have a look at the attached model, it does something like you need.
forum water example.mdl
(2.55 KiB) Downloaded 180 times
The only issue is that things are delayed by a month, but that makes sense as in the table you uploaded, "surface infiltration" is almost certainly measured over the whole month, but APWL must be the value at the end of the month. Reducing the time step would make this look much better.
Re: question
This is why I hate discrete time notation. It obscures stock-flow relationships. I think it's responsible for a lot of errors, especially in economics and social sciences.
I would rewrite this as an ordinary stock and flow:
AWPL stock = INTEG( loss rate, initial AWPL ) ~ units of something
loss rate = MAX(0, - infiltration) ~ units of something/time
elhamdavoodi
Re: question
thanks a lot for your reply
I am very happy that this problem has been resolved, but the value of APWL from this model not equal with excel value. I edited value and attached this model and APWL value in excel. Please in this case, guide me
(2.58 KiB) Downloaded 172 times
Re: question
I don't see the Excel attachment.
elhamdavoodi
Re: question
I mean this is APWL photo that attached
Re: question
Your data is misaligned. In your screenshot, infiltration = -26.6 happens at time 4, but in the model it's at time 5.
Is APWL and indicator rather than a physical stock?
elhamdavoodi
Re: question
this model created by Administrator
Re: question
In that case, there's no discrepancy, other than the input. It should work.
elhamdavoodi
Re: question
Administrator wrote:Have a look at the attached model, it does something like you need.
(2.6 KiB) Downloaded 164 times
Re: question
It's hard to diagnose "different" without having the Excel and Vensim models running on exactly the same infiltration data for comparison. The difference could be roundoff, or it could be a difference in inputs.
elhamdavoodi
Re: question
tomfid wrote:It's hard to diagnose "different" without having the Excel and Vensim models running on exactly the same infiltration data for comparison. The difference could be roundoff, or it could be a difference in inputs.
thanks for your reply
I attached excel data of surface infiltration and the APWL data Which should be calculated with vensim. The vensim mosel that created by Administerator is work very good and APWL value are correct but this value have a 1 month delay. How i can solve this problem?
Surface infiltration.xlsx
(15.5 KiB) Downloaded 156 times
Re: question
I think you'll have to use my original solution instead. Admin's version is more physically motivated, but there's no way to get rid of the lag in reporting the integration (though of course you could simply ignore it).
APWL previous = DELAY FIXED(APWL,TIME STEP,0)
APWL = IF THEN ELSE( infiltration>0, 0, APWL previous+infiltration )
Re: question
But again, if this is a physical process, not just accounting, it would be better to model it as a continuous time integration with TIME STEP << 1.
elhamdavoodi
Re: question
tomfid wrote:I think you'll have to use my original solution instead. Admin's version is more physically motivated, but there's no way to get rid of the lag in reporting the integration (though of course you could simply ignore it).
Thanks for your reply
This method worked well.
Thankful :D :D :D
Re: question
Do you want to model the physical process, or just replicate the results from the Excel table?
elhamdavoodi
Hi every one
I have a question about vensim:
I have use the condition function that if X in the time series=Max, then X+b, X
X is the number in the time step
How i can do this?
the attached pic my concept
thanks a lot
Re: question
If N is a proxy for time here, there are two answers.
1. This is acausal, i.e. it implies knowledge of the future, which is impossible both in reality and in the model.
2. If what you mean by MAX is the largest value encountered so far at time t, then it's possible. You could do the following:
maximum x = SAMPLE IF TRUE( x > maximum x, x, x)
y = IF THEN ELSE( x >= maximum x, x+b, x )
