Suppose a model is about age cohorts of a population. The age cohorts are from 0 to 100. If subrange A is from 0 to 90, subrange B is from 10 to 60, is possible to somehow "map" subrange B onto the subrange 0 to 50 of subrange A, without having to create a new subrange specifically from 0 to 50?
Thanks a lot.
Mapping subscript subranges that are of different sizes?
- Vensim version: PRO
Re: Mapping subscript subranges that are of different sizes?
You'll need to create the 0-50 subrange if you want to map to it.
An alternative for unconstrained mapping is VECTOR ELM MAP. It's easy to use, but also easy to make a mess.
Another option is to create a [from, to] matrix containing the mapping, with 0s and 1s in the relevant locations, and use it with VECTOR SELECT or SUM. The drawback is that this turns an n-dimensional problem into n^2. Often it doesn't matter though.
