I am trying to import data across time for optfertfromtext variable in the 01_yield view. However, I am getting floating point error. I have attached my .mdl and corresponding .vdf file. Could you help me understand how to solve this issue?
Best,
Mrunal
Data import using .dat file
- Data10.vdf
- (13.85 KiB) Downloaded 163 times
- nov22nd evening run3.mdl
- (150.28 KiB) Downloaded 159 times
Re: Data import using .dat file
You're missing a lot of data. Be sure you have warnings enabled (Tools>Options>Settings>Warnings:Display).
I think the immediate problem is that you have the Data Source field set to use "data.vdf" rather than "data10.vdf". (See the Simulation Control dialog, Advanced tab.)
After fixing that, I still get an FP error:
However, that's an ordinary model error, because the demand-supply balance goes negative, and is raised to a negative power (price elasticity).
WARNING: No data found for -Consumption animal products- in the exogenous data files.
WARNING: No data found for -Country area- in the exogenous data files.
WARNING: No data found for -energy share of maize on total diet- in the exogenous data files.
WARNING: No data found for -export maize- in the exogenous data files.
WARNING: No data found for -Floor Price NAMBOARD and Food Reserve Agency Real- in the exogenous data files.
WARNING: No data found for -import maize- in the exogenous data files.
WARNING: No data found for -Inland water- in the exogenous data files.
WARNING: No data found for -Nitrogen Fertilizer Price REAL data- in the exogenous data files.
WARNING: No data found for -optfertfromtext- in the exogenous data files.
WARNING: No data found for -Organic Matter from Animals- in the exogenous data files.
... similar warnings suppressed for additional variables
ERROR: Floating point error computing - effect of nitrogen on yield - at time = 1984.000000.
Trying to save the results anyway
ERROR: Floating point error computing - effect of supply and demand on producer price - at time = 1986.312500.
