Hi to everybody
is there any way to use the encolsed excel file as an input for a lookup function in Vensim PLE? With some efforts I translated the data so to get a series of values of the type (a,b),(c,d) but when I tried to copy and paste sush a series within a lookup I found some problems since only a small subset was really saved.
Any workaround?
All the best.
Lorenzo
Excel file as an input for a lookup
- Vensim version: PLE
- test.xlsx
- (25.03 KiB) Downloaded 195 times
Re: Excel file as an input for a lookup
Ok, sorry, I partially solved.. there were some missing , between the )( but the whole process is really boring.. is there any direct way to access the data within an excel file?
L.
L.
Not with PLE. You'd need PLE+, Pro or DSS to read the data directly.
Hi AdministratorAdministrator wrote:Not with PLE. You'd need PLE+, Pro or DSS to read the data directly.
thanks... so PLE+ is fine.... could you give me some hints? I know a collegue who has that version....
All the best.
Lorenzo
Have a look at the Vensim documentation, it has all you need (including examples) to read directly from Excel.
Specifically, the Help includes a sample model for every built in function, including the GET XLS variants. Sometimes the OS will lock out the links, but you can also find them in the Vensim folder (usually C:\users\public\vensim on Windows).
Ok, as Tomfid and Administrator suggested me, I looked at the documentation and the examples so I discovered I have non been clear enough. What I want to do is to load from an Excel file the tabular definition of a function f() and use it as f(x) with x \in [xmin, xmax] before the start of any simulation so to use it in a Vensim model with Time running from 0 to FINAL TIME and with, possibly but not necessarily, x=x(Time).
All the best.
Lorenzo
All the best.
Lorenzo
GET XLS LOOKUPS is the function that does this.
Hi Administrator, thank u a lot, it works really fine..Administrator wrote:GET XLS LOOKUPS is the function that does this.
Lorenzo
