When I run my model with new version of Vensim(6.3), I encounter with different results in comparision with previous version(5.7). Do you have any ideas to solve this problem? It is worth mentioning that the input data and model are same.
Best Regards,
Siamak Sheykhha
Different results in comparision with previous version(5.7)
Re: Different results in comparision with previous version(5.7)
Can you email the model to us so we can test?
You might also check any random number generation, that has changed,
http://www.vensim.com/documentation/ind ... se_rng.htm
Thank you for your response.
Can I send them in form of private message or I should send them in this forum?
Email to vensim@vensim.com
