Time Subscript
Posted: Fri Jan 05, 2018 1:30 am
by vahidi
How can I formulate time subscript for variables?
For example, how can I define the formula in the attached pic?
In that formula p is variable.
Thank for your attention.
Re: Time Subscript
Posted: Fri Jan 05, 2018 5:40 am
This looks like discrete time notation, and presumably the summation indicates some kind of state variable dynamics. Hard to say how to implement it without knowing what it's for.
Generically, your two choices are to implement it directly using a subscript to represent the elements of j, or to use a stock to represent the dynamics explicitly.
However, since l(t-1) is independent of j in the summation, this simplifies readily:
r(t) = 1/p * p * l(t-1) = l(t-1)
http://metasd.com/2017/11/discrete-time-stinks/
Re: Time Subscript
Posted: Fri Jan 05, 2018 11:29 pm
by vahidi
Thanks tomfid,
The correct argument is l(t-j) as shown below:
- Untitled.png (3.02 KiB) Viewed 3131 times
I want to model a simple lending system as shown below:
- Untitled1.png (52.73 KiB) Viewed 3131 times
In this system, loans are made every year and have a redemption period (p). Although p is constant, I want to change it in different simulation runs.
Every year we must repay 1/p of the principal of each loan until full redemption. In fact, the r(t) is the amount of repayment each year that should be calculated by p and l.
Time Subscript
Posted: Tue Jan 09, 2018 2:05 pm
by vahidi
- Untitled1.png (52.73 KiB) Viewed 3112 times
For example, how can I define the formula in the attached pic for the loan redemption?
- Untitled.png (3.02 KiB) Viewed 3112 times
Re: Time Subscript
Posted: Tue Jan 09, 2018 2:13 pm
If I'm understanding correctly, all you need is
debt redemption = loan amount / loans redemption period
Re: Time Subscript
Posted: Tue Jan 09, 2018 11:55 pm
I've attached a model of a loan. It gets a little messy if you're interested in exact representation of compounding and payment periods, as you can see. This could be quite a bit simpler if you assumed continuous time and payments.
