vensim function
eddypra
vensim function
Post by eddypra »
Dear vensim forum,
Hi, I'm a newbie in systems dynamic & vensim. I've downloaded vensim PLE for
creating a very simple model. I need a (integer) variabel that (automatically) varies (increment) 0,1,2,3,...10
along with the initial time (from 0) to final time (100) with step of 1.
step : 0, 1, 2, 3, 4, 5, 6, 7,....., 100
output function: 0, 1, 2, 3, 4, 5, 6, 7,....., 100
I want to know if vensim has the function for that?
Thank for your help.
Eddy
Re: vensim function
There is an INTEGER function, does that do what you need?
Or simply use the variable "time".
Re: vensim function
Create a stock, with inflow 1/TIME STEP?
Re: vensim function
Or just use INTEGER(Time).
However, you should avoid creating something that's tied to a particular time step. http://metasd.com/2017/11/discrete-time-stinks/
eddypra
Re: vensim function
Post by eddypra »
Thank to all the reply. I've just found the answer.
The answer is giving a variabel and let the equation -->TIME BASE (0,1)
Re: vensim function
x=TIME BASE(0,1)
is the same as
x = Time
when INITIAL TIME=0 and TIME STEP=1.
