I would like to know if there is a way to export from vensin only the results of only one variable.
Export variables
Re: Export variables
Yes - you can specify a savelist in the export dialog, or at runtime (the first is usually preferred).
Another option is to simply use the table tool and copy-paste.
http://vensim.com/documentation/ref_savelist.htm
http://vensim.com/documentation/23500.htm
- Vensim version: PLE
Anyway if you export in either a .tab or a .xlx file you can use excel to gather only the data of the preferred variable....Priscila wrote:Hello,
Lorenzo
