Hi there ,
I am trying to input a time series data to dictate the behavior of a flow into a stock. I need the "Get Time Value" function to make this work, however given I am using PLE, this is not an option. How do you advise I go about this? I have attached the relevant time series and my model. I am trying to feed the time series into the "rate of battery charging" flow.
Thank you.
Ola Osman
Inputting Times series Data for flow rate into a stock
- Time series.xlsx
- (670.53 KiB) Downloaded 180 times
- RE NH3 Production.mdl
- (5.97 KiB) Downloaded 209 times
Re: Inputting Times series Data for flow rate into a stock
Use
PV output = PV Profile ( time )
Hi there,
Thank you for your response. For the time, should I add that as another variable feeding into "PV Output"? And if so, how do i set it up so that this varies with simulation time?
Thank you.
Ola
Thank you.
Ola
"Time" is already a protected variable in Vensim, it's the simulation time.
Add a new shadow variable to your view and select "time". Then you can draw the arrow you need.
Hi there,
Thank you for that. One more follow up question please. I am trying to get the PV output to repeat every 24 hours. I tried using the PULSE TRAIN function as per the attachment but I could not get it to work. Can you please advise?
Thank you.
Ola
Thank you.
Ola
- Final RE NH3 Production.mdl
- (8.82 KiB) Downloaded 197 times
Create a new variable
And then use this instead of "time" in the call to the lookup
hour of day = modulo ( Time , 24)
PV output = PV Profile (hour of day)
... and you should really make the 24 a parameter with units,
hours per day == 24 ~ hours or hours/day (depending on use)
