I cannot manage to create a "buildings inventory" depending on their "energy class". I guess this is actually easy to do, probably with subscripts mapping, but I don't understand how to use it.
I created a subscript "energy classes" : A,B,C,D
And another subscript "buildings" : (Building1-Building15)
The model calculates the energy consumption of every building at every time step.
These consumptions must correspond to an "energy class" (for instance : energy consumption of Building1 < 50 -> A class ; I need to do this for every building). I don't know how to map this nor if it is possible.
Then I would like to make an "inventory" of buildings for each "energy class" such as : A class = x (buildings) ; B class = y ; C class = z ; D class = zz (x+y+z+zz = the total number of buildings, here 15).
Can you please help me with this ?
Best regards,
Laura
Mapping subscripts to create an inventory
Re: Mapping subscripts to create an inventory
I'm struggling to follow what you need without a model to look at. But here's a guess.
energy consumption class limit[energy class a] = 50 {don't know what the other energy class limits are}
energy class[building] = IF THEN ELSE ( energy usage[building] < energy consumption class limit[energy class a] , 1 , 0 )
+ IF THEN ELSE ( energy usage[building] >= energy consumption class limit[energy class a] :AND: energy usage[building] < energy consumption class limit[energy class b] , 1 , 0 )
inventory of buildings[energy class] = sum ( if then else ( energy class[building!] = energy class , 1 , 0 ) )
It worked perfectly ! With a little adjustment of the equation for the inventory, but still I managed to obtain what I wanted from the model.
Thanks a lot !
Laura
Thanks a lot !
Laura
