Can't use Get xls lookup in If then else function
VSEE1906
Post by VSEE1906 »
I am new in Vensim and just developed a small model for energy demand based on GDP and Energy Intensity (EI) considering a time frame 2000-2035. EI has historical data from 2000 to 2016, and I have used a variable named "Historical Energy Intensity by Sector and Source" which gets the data from an Excel file using GET XLS LOOKUPS. I have another variable named "Projected Energy Intensity by Sector and Source" which uses equations in order to determine EI from 2017 to 2035.
I also have created a Variable named "Energy Intensity by Sector and Source". I tried to use the IF THEN ELSE function in order to get "Historical Energy Intensity by Sector and Source" for time <=2016, and "Projected Energy Intensity by Sector and Source" from 2017 to 2035. When I check the model an error appears stating that I cannot use a lookup as argument in the IF THEN ELSE function. Is there any other way to call the data?
Data input Ecuador.xlsx
(211.99 KiB) Downloaded 172 times
20180315_Demand-GDP_EI.mdl
(4 KiB) Downloaded 190 times
Re: Can't use Get xls lookup in If then else function
GET functions have to appear first on the left hand side of an equation. See http://vensim.com/documentation/fn_get_xls_lookups.htm
Make the lookup a separate variable containing the GET. Then you can use it in other equations. Like:
mylookup = GET XLS LOOKUP( ...
price = IF THEN ELSE( time > 2, mylookup(quantity), ...
