I have a problem with my Vensim model. my final time is 10 years and in setting I chose initial time= o and final time=10 but in simulation, my model is shown only for 2 years?
please help me?
adjust final time
Re: adjust final time
Can you upload the model so we can take a look? It could be a number of things that is causing this.
yes, sure.
I'm looking forward to your guide.
thanks
thanks
- 2.mdl
- (7.11 KiB) Downloaded 184 times
It only runs to 2 as you have a floating point error which stops the simulation.
Given the size numbers you are dealing with, I'd suggest converting them to "million people" instead of "people". This will probably fix the floating point error.
thank you very much.
The likely cause is a division by zero or runaway exponential, perhaps from a feedback loop with the wrong polarity.
