Looking for the beer game in vensim
I am looking for a Vensim version of the Beer game.
is there a version that is different from the Kirkwood's one taught at Arizona university?
Re: Looking for the beer game in vensim
Hi Tom
Thank you for your reply.
In fact i am working on a model that imitates Kirkwood's model that curiously has no units.
In this model orders are generated with a random normal function and the first value at time 0 is used to intialize a smoothing function. But the value in the smooth does not represent that value. See the model joined that behaves strangely.
that first value is changed into another one without explanation. How can i get the right value back?
Best regards.
essai.mdl
(2.02 KiB) Downloaded 257 times
Ah, yes. This is because the initialization step differs from the first dynamic step. I think you can see what's happening if you change from Euler to Diff integration (that just changes storage order; the computations are the same).
It seems like there must be a trick for working around this - but it might be easier to simply fix the first value at a nonrandom constant.
