Is there any help available for building a Venapp- a management flight simulator.
I have a model which I need to present to client. Aim is to play and experiment with the model without getting to know the equations.
Unfortunately, publishing with Forio Systems is not possible as client has quite a low technical knowledge and not interested in getting to know new platforms.
Venapp
Re: Venapp
There is a whole section in the help system on Venapps, have you looked at it?
http://www.vensim.com/documentation/ind ... enapps.htm
The best thing to do is to take an existing one and modify it, you'll find demo venapps on your machine where you installed the help/sample models (search for *.vcd).
Re: Venapp
Another option worth looking at is Sable, which gives a cleaner-looking result than VenApp.
