Vensim constant behavior
anca91
Post by anca91 »
Hello everyone, sorry if this topic could be banal. I have the following model and I try to verify his behavior. Unfortunately, when I start the simulation I get a constant trend, when I expect a decrease in the number of uninfected and an increase in the number of those infected. You could kindly help me. :oops:
Stock_and_flow_.mdl
(3.67 KiB) Downloaded 173 times
Re: Vensim constant behavior
Try changing
rate of plant infections = Plant Infected/LATENCY TIME
to
rate of plant infections = Plant Not Infected/LATENCY TIME
At t = 0, the number of plants infected is zero. So rate of plant infections is also zero.
anca91
Post by anca91 »
thanks for the reply, I tried to do what you say. but I get this answer: :cry:
ERROR: Floating point error computing - rate of plant infections - at time = 34.000000.
Trying to save the results anyway
Have a look at a table of the values for rate of plant infections and see what is happening.
anca91
Post by anca91 »
I can not find a meaning
file_output.pdf
(6.66 KiB) Downloaded 158 times
One problem is that your model is running for 100 years with a time step of one year. This needs to change, the time step should be 1/4 of the smallest delay in your model (I think this is 0.08333, the "latency time").
What is the "latency time"? I know it's value is one month, but what actually is it?
anca91
Post by anca91 »
It is the time it takes to understand how much time there is between when a plant shows the disease and when it takes the infection. :roll:
The model will not generally be stable unless the time step is shorter than the shortest delay. Powers of 2 are generally better, so perhaps .03125 would be a good start (you can set this via the dropdown menu at Model>Settings>Time Bounds.
