longest run of zeros
danraymond53
Vensim version: PLE+
Post by danraymond53 »
I have a flow that can either 650 or zero depending on other conditions. I need to calculate the longest period where the flow remains zero.
e.g. 650,650,0,0,0,650,0,0,0,0,0,650,0,0 the answer would be 5 (days in my case).
I have PLE Plus is there a way to code this?
danraymond53
Re: longest run of zeros
I realise how I can solve this.
But I need to reset a level to zero after the data stream changes back to 650 (having accumulated the count of zeros in another variable).
I can't find a way to do this, is there a reset variable command?
danraymond53
Got it:
Used IF THEN ELSE to catch when zero stream started and count it. Used SAMPLE IF TRUE to find the maximum length of the counted stream.
joined a model to reset a level to 0. Does not use the sample if true, normally not available in PLE plus.
resetting.vpm
(19.65 KiB) Downloaded 186 times
danraymond53
Thanks LAUJJ
that cleaned it up!
