I am new to Vensim and could use some help.
Lets say I have a part, call it bearing. It starts off with a 100% condition. I set a rate, call it wear. It starts off with 1 (0-100 min-max). Simulation steps are in weeks.
So far, simulating gives a linear slope of the bearing condition. From here on I get stuck:
I want to introduce a level, call it oil level. It starts off at 100, and is empty at 0. As this level goes down, I want the "wear" to increase exponentially. This should result in that the bearing condition no longer remains linear.
+ What does the "auxiliary" do? How does it work compared to constant or level.
New user, simple questions
- Capture6.PNG (92.04 KiB) Viewed 2218 times
Re: New user, simple questions
It might be better to take a step back and go through some of the tutorials.
On this page you will find a really good Vensim PLE tutorial.
wear rate = EXP(k*oil level) is not what you want, because it's increasing in oil level. You might try something like
wear rate = normal wear rate*EXP( wear sensitivity*(oil level - critical oil level) )
with wear sensitivity < 0.
Another alternative would be to use a lookup, like
wear rate = normal wear rate*effect of oil on wear( oil level/normal oil level )
it works, thanks guys.
