Model CDF without a closed-form solution
WayneZhou2009
Post by WayneZhou2009 »
Hi Tom and everyone,
This might be trivial. However I searched the forum and did not find the answer to it. I am trying to model the cumulative distribution function (CDF) and hazard function of certain distributions that do not have analytical expressions (closed form solutions).
The background is that I want to model the discard rate of my products per year. For example, I have 100 new products in 2018 and their lifetimes are assumed to follow a given distribution, say, normal distribution. In 2019, I have another 150 new products and their lifetimes follow the same distribution. And so on. The distribution remains unchanged, regardless of TIME. In other words, the hazard rate consists of a number of constant values, e.g. 0.02 for 1-year-old product, 0.025 for 3-year-old product, and so on. A 3-year-old product has the same risk of discard, no matter whether it is produced in 2018 or 2028. So it is not about Vensim's built-in random functions that return random numbers.
Now, if the distribution has a closed form solution for its CDF, the hazard function can be easily defined. For example, for Weibull distribution, the hazard function is given by h(x) = (shape/scale)*(x/scale)^(shape-1), where x is the age of product.
However, if the distribution does not have a closed form solution for its CDF, then how to realize the above in Vensim? An example is normal distribution, or lognormal distribution. Note that I do not want to use a lookup or get Excel constants, because I want to be able to change the parameters of the distribution within the model so that its hazard function can vary accordingly. I understand that a lookup is "fixed" once it is defined. (Please correct me if I am mistaken).
I am aware of the Delay Profile function but it uses the lookup to define the profile, hence it is not what I need. Would some sort of approximation of the CDF in a closed-form expression be the only way to go?
Thank you so much.
Re: Model CDF without a closed-form solution
My "stats" is not so strong. Does the following help?
http://metasd.com/2010/05/cumulative-no ... tribution/
or
viewtopic.php?t=3438
WayneZhou2009
Hi Administrator,
Many thanks for your quick response. Yes I did come across the second one, i.e. viewtopic.php?t=3438 . So, it appears that using a closed-form expression to approximate the CDF is the way out? I am concerned about the accuracy of the results of this method.
I wonder if it is possible to sort of "integrate" the PDF into the CDF in Vensim. However, this integration is different from the conventional way of integrating flows into a level in Vensim, where the flow and the level are time variant. Here in my case, the CDF needs to be invariant over real time (year 2018, 2019, 2020, and so on), as it only applies to a product's age ( 1-year-old, 2-year-old, and so on). To describe it in another way, the CDF profile (and the derived hazard profile) is cross-sectional, but not time-series.
Any thoughts and enlightenment are greatly appreciated.
Note that the NORMAL CDF macro is now built-in to Vensim. The numerical approximation is quite precise; I think it would be rare to find a case where any error was meaningful relative to other uncertainties in the model.
For other distributions, you could write an external function.
WayneZhou2009
Hi Tom,
Many thanks. I did not know there is a NORMAL CDF function available now in Vensim. Just found in my Vensim (version 7.1). But it does not appear to be covered in Vensim Help? Please could you let me know where more details about this function.
Thanks.
tomfid wrote:Note that the NORMAL CDF macro is now built-in to Vensim. The numerical approximation is quite precise; I think it would be rare to find a case where any error was meaningful relative to other uncertainties in the model.
It's based on the macro from MetaSD that Tony linked - same inputs.
I'll add it to the help.
A lookup is not fixed and you can vary it using the vector lookup formula.
See the model joined.
lookup.vpm
(15.73 KiB) Downloaded 231 times
Correct, but you can't use VECTOR LOOKUP with DELAY PROFILE.
WayneZhou2009
Thank you both so much, Tom and LAUJJL !
