I have four levels that have accumulated maintenance events over time (520 weeks)
Each of the four levels have accumulated to approximately 20 events.
When I sum all the four levels in a "overall" level, the sum is over 20000, it should be roughly 80. I think that all the other levels give a weekly amount even though the amount of events don't increase.
E.g. from 15 to 16 events may happen after 8 weeks. But it gives the value 15 for 8 weeks =120, whereas I only want the value when it increases.
How can I accumulate these levels only when they step up by one amount? -Is it possible to take a value "Now" minus value "yesterday" ? If it is 15 to days in a row, its 15-15 = 0. If it increases, 16-15 = 1.
I am using PLE 7.2a
I uploaded the model
Accumulation of other levels
- System Design V1,9.mdl
- Vensim file
- (6.69 KiB) Downloaded 182 times
- Screenshot
- capture 9.png (56.5 KiB) Viewed 1718 times
Re: Accumulation of other levels
If you had units in your model, you would find the problem immediately.
You don't use a level to sum up other levels. All you do is add them together.
total maintenance hours used elm = acccorrectivem1 + acc replace bearing el 1 events + accfillingevents 1 + acc change oil events 1
Excellent. I got it to work. Thank you so much for the quick reply.
