Showing sensitivity graph in Venapp
Hossein
Post by Hossein »
Dear Tom/Administrator,
I have a problem with showing sensitivity run in Venapp. For a normal run, I can show its graph and table through the following commands:
WORKBENCH>GRAPH
WORKBENCH>TABLE
However, this method does not work in case of sensitivity graph. Could you please help?
Cheers,
Re: Showing sensitivity graph in Venapp
Do you have a sensitivity graph in your toolset? If yes, just use WORKBENCH>name_of_sensitivity_tool
Hossein
Post by Hossein »
Let me correct my question. using WORKBENCH>SENSITIVTY GRAPH actually works in venapp and shows its related sensitivity graph, however, I have put a button which user can select from the list of variables to see its sensitivity run. The command of the button is "SPECIAL>VARSELECT|Variables". However, after selecting a new variable, sensitivity graph does not change!
What happens if you use the REFRESH command after selecting the variable? I cannot remember the actual command (it's something like SPECIAL>REFRESH).
