copy/paste
Sara T
copy/paste
Post by Sara T »
I have made two separate vensim files,there are my two subsystems, and I want to copy everything from one system to another.
My problem is that when i select all, copy it, then I can not paste it in the other vensim file.
My vensim version is Vensim PlE.
Is this workabale in this version?
please guide me.
It's more than an hour that I'm involved with this problem.
Re: copy/paste
This should work:
  • Open model A
    Select All
    Copy (Control-C)
    Close model A
    Open model B
    Paste (Control-V)
I just tested on a model successfully - what's not working for you?
Sara T
Re: copy/paste
Post by Sara T »
I also did the same, but when i open model b , the Paste button is disabled and shortcut key(ctrl+v) also doesn't work.
Re: copy/paste
Are you closing Vensim in between, or using two different running instances of Vensim? The clipboard may not carry over. Be sure to just close the model.
Sara T
Re: copy/paste
Post by Sara T »
Yes i close model a and then open model b.
Sorry
I really do not know where is the problem :( :(
Re: copy/paste
Can you post the models?
Are you on Mac or Win?
Sara T
Re: copy/paste
Post by Sara T »
I'm on windows 10.
I attach part of my subsystems.
B.mdl
(5.02 KiB) Downloaded 886 times
A.mdl
(2.18 KiB) Downloaded 851 times
Re: copy/paste
If you copy and then immediately paste in the same model, does it work?
Re: copy/paste
AB.mdl
(6.28 KiB) Downloaded 966 times
Sara T
Re: copy/paste
Post by Sara T »
thanks for your help
please see the video and correct me.
I want to do this action myself.
New folder.rar
(1.39 MiB) Downloaded 901 times
Re: copy/paste
The problem is that you are closing Vensim, this empties the clipboard.
1. Open Vensim.
2. Open the source model.
3. Copy all.
4. Do not exit Vensim.
5. Click File->Open, and open the target model.
6. Paste.
Sara T
Re:copy/paste
Post by Sara T »
Thank you so much.
The problem was solved.
