When I check my model, I encountered with one warning in unit check.
how can I remove the warning
I try to remove with suppresses warnings But did not work
remove warning in unit check
Re: remove warning in unit check
You'll need to fix the unit error. What is it?
Warning: units in equation for - labor index
Lookup - labor lookup table- used with dimensioned argument person
Because of the compatibility of other relevant calculations, i must use dmnl unit
You can do something like the following:
labor index = labor lookup table( labor / unit person )
where "unit person" is an unchangeable constant with value 1 and unit of people.
Thank you.
My problem was solved with your help.
